Electric force and its proportionality on charge(q)
Discussion in 'Physics' started by logearav, Jan 5, 2012.
  1. logearav
    Aug 19, 2011
    248
    The Electric field due to a source charge Q is defined in terms of some test charge q. Electric force F is proportional to q. Upto this i understood. Now the next line of my book says, Since F is proportional to q, the ratio F/q does not depend on q..
    I dont understand the text highlighted. Why F/q does not depend on q?
    Revered members, please throw light on my query.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Well if F is directly proportional to 'q' then F=K*q, where K is some constant of proportionality.
    Hence the ratio F/q=(K*q)/q=K, which being a constant is independent of q.
    logearav likes this.
  3. timekeeper
    Oct 24, 2007
    8
    Let Q be the charge which causes an electric field, q1 the test charge and r the distance between them. The Force that q1 experiences at distance r because of Q is:
    F(q1)=K\frac{Q*q1}{r^2} This is your first equation.
    Now take a different test charge q2 and put it at the same distance r again. For q2 the Force because of Q is:
    F(q2)=K\frac{Q*q2}{r^2} This is your second equation.
    Now, notice that \frac{F(q1)}{q1} is equal to \frac{F(q2)}{q2} !!! And since we define E=\frac{F(q)}{q} = \frac{K\frac{Q*q}{r^2}}{q} \Rightarrow E= K\frac{Q}{r^2}
    As you can see, we have reached to an equation which considers only source charge Q and distance r from Q.
    The Electric field of a given charge Q at a distance r from it is always the same, no matter what test charge q you put there.
  4. logearav
    Aug 19, 2011
    248
    Thanks for your valuable replies t_n_k and timekeeper. It is so helpful to me
