Electric fly swatter dead
Discussion in 'Technical Repair' started by Klaidas Stumbras, Jul 7, 2016.
  1. Klaidas Stumbras
    Jul 7, 2016
    19
    Trying to repair this thing the thing is it broke like a year ago and i dont really know where to put what so can anyone help me with this ?
    Also there was this small resistor near it i dont know if it is from it or not ... ;D i have the missing transistor and light emiting diode but i dont know where to solder it ...
  2. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    Are you trying to fix a $2 fly swatter ??
  3. Klaidas Stumbras
    Jul 7, 2016
    19
    why not when you have spare parts ? also its really hard to get those where i live
  4. wayneh
    Sep 9, 2010
    12,394
    3,246
    Why not? Because it will be nearly impossible without a schematic - which may be very hard to find - or another similar unit to copy.
    How did the parts get separated in the first place? (Not that it matters, just curious how it came to be in pieces. )
  5. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    I think Bigclive did a tear down on youtube..
  6. absf
    Dec 29, 2010
    1,493
    374
    May be you can refer to this link to get your swatter repaired....
    Allen
  7. absf
    Dec 29, 2010
    1,493
    374
    I did some study on your PCB and this is what I came out with...
    The transistor can either sit on the blue line or in the black line. Is the 1K resistor on top right the one that came out?
    Next you need to use an ohm meter to see continuity on the transformer. I think A-B is one coil and C-F another. What about D & E? Is there any continuity?
    Allen
  8. Klaidas Stumbras
    Jul 7, 2016
    19
    The transistor exploded thatsw why I desoldered the low voltage side
  9. Klaidas Stumbras
    Jul 7, 2016
    19
    Can't check the continuity as I m not at home .You got the V+ and 0v in terminals wrong way
  10. Klaidas Stumbras
    Jul 7, 2016
    19
    There is a resistor in that top right
  11. Klaidas Stumbras
    Jul 7, 2016
    19
    I could only find one coil resistance without desoldering the transformer coils tho are connected somewhat like this i think
  12. debe
    Sep 21, 2010
    955
    185
    This is out of a electric fly swatter.Forgot R1 in the + feed 680ohm. BUG ZAPPER CICUIT.JPG BUG ZAPPER.3.JPG
    Klaidas Stumbras and absf like this.
  13. Klaidas Stumbras
    Jul 7, 2016
    19
    Thanks fixed and working
    absf likes this.
  14. Klaidas Stumbras
    Jul 7, 2016
    19
