I believe a spectrum analyzer test should be made to figure out the short and nominal working frequencies.
Need some figures to work with.
Main problem its big and heavy, I need a hand to move it outside, (when it isnt raining of course!), then I can set up near the fence, or does anyone know how to pick up the frequency from say 15 meters?
I could get a wire strand from the fence to within 15 meters of the lab, would a wire in the LF socket of analyzer pick up the frequency from that distance? I could probably pick out the clicks, and I am assuming that the interference while a different frequency, will peak with the clicks?
Your right I need to experiment. The frequency analyzer is one bit of test kit I havnt used much. I should try and get the manual for it if I can
