Electric circuits proplem
Discussion in 'Homework Help' started by tinhnho, Aug 31, 2004.
  1. tinhnho
    Thread Starter Active Member
    Aug 31, 2004
    34
    hi everyone
    i really need help with this proplems,i totally stuck from begin.
    Given: R1= 2 ohm, R2 =1 ohm, R3= 3 ohm, R4= 2 ohm, R5 = 3 ohm, R6 =3 ohm
    1. The voltmeter in the figure give a reading of v =1 V,and the resistances are given. Use the KCL and KVL to determine what the source woltage Vs must be in order to get this measured result. You will need to use both KVL and KCL, one node at a time or one branch at a time
    p/s: sorry that my hand drawing picture
    KCL = Kirchhoff's current law
    KVL= Kirchhoff's voltage law
    Vs= voltage source
    Is= current source
    Here is the Answers:
    Vs= 20.666667
    v1 = 6 ( where R1, R2, R3 join)
    v2= 2 (where R3, R4, R5 join )
  2. haditya
    Jan 19, 2004
    220
    can u post the circuit diagram
  3. nithin
    Member
    Aug 27, 2004
    15
    defintely need the circuit diagram... because it doesn seem to be a ladder circuit or have you rounded off the values of v1 and v2
  4. nithin
    Member
    Aug 27, 2004
    15
    you got to first find the equivalent impedence ..... so the current
    I=(11*Vs)/31
    V1=(9/11)*I (by current division)...
    V2=(3/22)*I....
    v=1=(3/22)*I...
    you have to first find I and then substituting .. ull get the reqd. answers
  5. Iwan
    Member
    Jul 14, 2004
    23
    May I see the circuit?
  6. tinhnho
    Aug 31, 2004
    34
    sorry that i didn;t post the diagram, Anyway i figured out how to solve the proplem,thank you
