electric car project
Discussion in 'The Projects Forum' started by eddien123, Apr 10, 2011.
  1. eddien123
    Apr 4, 2011
    Hi Folks
    I currently doing a project for my degree, it is to simulate a electric car on PSIM,
    I was going to use a 3 phase induction motor, but i've been told a DC motor would be better for regenerative braking, Does anyone know how to set up a DC motor in PSIM - Ra, La, RF, Moment of inertia setting etc, for a motor big enough to power an electric car?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Some parameters might be nice to provide.
    That is a very indefinite description. What would you suggest as a total mass of the vehicle, what sort of power output for the motor, what voltage from the battery pack?
  3. christopher.black
    Apr 11, 2011
    I am planning to convert my 1977 Chevy Luv pick-up to all electric.
    You could start from there for your school project.
    The gross vehicle weight is 3,550 lbs, 2,440 lbs empty with a load of 1,125 lbs including passengers, ect... The power rating on the original motor is 80 Horsepower and 95 ft lbs of torque at 3,000 rpm.
    If you figure you will loose 20% of the rated power on your DC motor due to combined inefficiencies, a 100 hp motor will put out about the same power of the stock 80 hp gas motor, and electric motors generally have plenty of torque.
    However, the added weight of the batteries will likely top of the 1,125lb payload, and the original engine is underpowered. With that in mind I am looking into using two 100hp motors one on each back wheel. If I am going to spend $10,000 to rebuild a vehicle I might as well spend an extra $3000 to give it more power.
  4. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Sorry, no info on PSIM, but I'd argue the claim on the DC motor. My direction would be 3phase brushless PM.
