Electret microphone tester
Discussion in 'The Projects Forum' started by MMH, Feb 28, 2013.
  1. MMH
    Feb 8, 2013
    143
    Hello there everybody!! I have some electret microphones which I want to test-whether they work or not, since they are pretty old now. Can you please recommend a simple circuit with which I can test the mic? I also want to make a circuit using NE555 to which would amplify all that I will talk to the microphone- to the speaker so that I can hear my voice from the speaker.
    Thanks in advance for your help!!
  2. MMH
    Feb 8, 2013
    143
    So, does that mean that there are no such circuits using NE555?
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    555 is more of a switch/timer than an amplifier.
    If you have a transistor, you can test it. Electret microphones need a bias voltage, very low current at 2-5V is typically used. The output can then feed a single transistor.
    Here's a very basic circuit for an electret microphone, follow the thread for a better one.
    Install free SoundCard Scope to see the waveforms.
    I gave a bit of direction on using SoundCard Scope in This thread Just remember to include the voltage divider and diodes so you don't damage your computer sound card input.
