Electret Mic Pre-amp
Discussion in 'General Electronics Chat' started by AetherNZ, Aug 18, 2010.
  1. AetherNZ
    Mar 23, 2008
    21
    I am carrying out a few acoustics experiments with electret mics. I am currently using the attached preamp circuit and measuring magnitude and phase using a 1Mohm Zin impedance analyzer, which works fine. I need to start carrying out the same experiments on a vector network analyzer with a 50ohm input impedance. My current preamp circuit is getting loaded down by the VNA.
    The VNA has a +30 dBm +-7 V MAX input @ 50 ohm, so ideally this would be taken into account with voltage limits ect.
    Any suggestions on what type of amp circuit I could use? Low noise is especially important across as a wide frequency band if possible (20 Hz - 30 kHz +).
    I found these circuits posted by Audioguru and SgtWookie:
    Thanks a lot! :D
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. AetherNZ
    Mar 23, 2008
    21
    How well would that chip handle the 50 ohm load and be able to supply close the the +30dBm to get full scale measurements?
    I came across this high current op-amp that seems suitable: TS921?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
