Elecronic Dice HW problem
Discussion in 'Homework Help' started by circuit42, Mar 8, 2011.
  1. circuit42
    Mar 8, 2011
    Using 555 design and ICs we have covered in class (no counters), design (in MultiSim first), and construct a single die dice game. The game will operate such that when you press a pushbutton the die “rolls” and when the pushbutton is released a random value is displayed on 7 LEDs arranged in the pattern of pips on a standard cube die. The values displayed should be 1 through 6 but it is acceptable if you occasionally get a “0” (no LEDs lit).
    How do I construct a counter without using one in my circuit? I am also using a 555.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    You can make your own counter using JK Flip Flops. Here 's some background on it:
    http://www.allaboutcircuits.com/vol_4/chpt_11/2.html
    If you have a masked oscillator output you can use that one to excite the first FF. Otherwise you must mask it yourself with your control signal.
