Elec1230 - Waveform, Phasors, & Calculations
Discussion in 'Homework Help' started by dennis.muller, Jun 8, 2008.
  1. dennis.muller
    Feb 5, 2008
    10
    I'v posted here a copy of my work in the hopes someone could pin point where i'm going wrong or give me some understanding on how to solve the problem correctly. The problems I'm having are with questions # 41 to 51.
    These questions are from the following book chapter 15 pg 501,
    Circuit Analysis Theory and Practice
    by Allan H. Robbins
    ISBN-10: 141803861x
    ISBN-13: 978-1418038618
    Hardcover, 2006
    Edition: 4
    PG1 Q7-11
    PG2 Q13-19
    PG3 Q21-23
    PG4 Q23-25
    PG5 Q27
    PG6 Q29
    PG7 Q31-33
    PG8 Q33-35
    PG9 Q35-37
    PG10 Q39-41
    PG11 Q41
    PG12 Q41-43
    PG13 Q43
    PG14 Q45-51
    PG15 Q51
    PG16 Q55-57
    PG17 Q57-59
  2. jorgemotalmeida
    Member
    Oct 23, 2007
    23
    http://home.cogeco.ca/~dennis-muller/ELEC1230-01/ASS2/Image (3).jpg the first part is correct. With TI calculator it is easy. Check the mode to RADIAN. And then put the value desired. Example: press 50, then press the ANGLE (2nd key + ANGLE key) choose the degree symbol and then press twice in ENTER. you will have the radian value quickly.
  3. dennis.muller
    Feb 5, 2008
    10
    Thanks for the prompt reply to my problem. The problem questions you refured to I have no problems with, my problems start with question 41 and end with question 51. With these questions, yes I have tryied calculating both in rads and degs with no succsess.
  4. dennis.muller
    Feb 5, 2008
    10
    I requested some help from my professor who had the following below to say. I posted his reply as a resolution to this posting.
    Hi Dennis:
    I don't have enough time to go over each question, but hopefully the
    following remarks will help:
    29c: You made a calculation error. You used an f of 120 microseconds
    when it was already calculated to be 8.33 kHz. Otherwise method is good.
    39) You are given that the waveform reaches its peak at 54 degrees. This
    means that it crossed the horizontal axis at -=36 degrees. That tells
    you that the phase angle theta is + 36 degrees. You are not given the
    period but are told that the portion from crossing the vertical axis to
    the end of the cycle is 1620 microseconds. This represents 360 - 36
    degrees = 324 degrees. Therefore to get the period, mutilply 1620 by
    360/324. Then you can get the angular velocity and be off to the races.
    41) You made a mistake I noticed in the drawing. Period is 50 ms and you
    are correct in that, but the rising edge of the waveform is not at t=0
    but later, so the end of the complete cycle is not at 50 ms but
    correspondingly later.
    For the rest, you need to start with the equation:
    v = Vm sin(wt + theta). Here theta is 45 degrees, as you know. In order
    for the instantaneous voltage to be zero, the argument of the sine
    function must be zero, and you got this correct in part a). For 23
    degrees, you have to say:
    v = Vm sin (wt + theta) where you know v is 23 v and you want to find t.
    You have to figure out at what value of t the sine function sin (wt -45
    deg) equals 23/30. This is done by using the inverse sine function. Say
    sin (-1) (wt-45 deg) = 23/30. (excuse my notation -- by sin (-1) I mean
    inverse sine.
    Same thing for -23 v.
    43) You are making a general mistake which makes all your drawings
    wrong. I suggest you review the Angles and Phasors handout and also the
    solution to 43c which is in the Problem Solutions I posted. Basically if
    theta is zero, the waveform crosses the horizontal axis at t=0. Let us
    class this waveform 1. If we have another waveform, waveform 2, that
    leads waveform 1, then its phase angle is going to be positive and it is
    going to cross the horizontal axis BEFORE waveform 1, which means before
    t= 0, i.e. at some negative value of t. If your horizontal axis is
    scaled in angle (wt) as we usually do, this means that waveform 2
    crosses the horizontal axis at a negative angle. Similarly if waveform 3
    lags waveform 1, then it crosses the horizontal axis LATER than waveform
    1, which means to the right of the vertical axis, at a positive value of
    t, at a positive angle.
    You need to be clear on this for the test. I will take up such questions
    in the Monday class.
    45) Probably similar mistake. See number 46 in the problem solutions.
    47) Average value is the area under the curve. Areas above the x axis
    are positive, areas under the x axis are negative. Since all of these
    curves are symetrical above and below the x axis, adding areas gives
    zero.
    51) This is a case of superiimposed ac and dc. The ac portion is e = 25
    v sin(wt). and the DC portion is constant 15 v. Since they are in
    series, they add. The effect is that the AC waveform is shifted upwards
    by 15 v. The equation is e = 15 + 25 v sin(wt), not what you had. As far
    as average is concerned, the formula you used does not apply to this
    case. The formula Vavg = .637 Vm is applicable only to a pure sine wave.
    Here y ou need to think in terms of the area under the curve. The AC
    portion cancels itself out, leaving the Dc value as the average. This is
    all explained on page 491 of the text.
    55) Your answer for a) and b) are correct. See solution to c) in the
    Problem Solutions posted. We did not deal with cosines in class but if
    you do, you have to use a trigonometric identity (see inside cover of
    book) to convert from a cosine to a sine.
    57) a) This is a case of superimposed ac and dc and you need to use
    equation 15-31. Read page 495.
    59) You have to use equation 15-30.
    Hope this helps.
    Ian Hyman
    Instructor,
    ELEC1230
