elctric charge
Discussion in 'General Electronics Chat' started by ronn, Nov 16, 2007.
  1. ronn
    Nov 1, 2007
    16
    hi, my name is ronn and i 'd like to ask what is really this electric charge means. I'd read some information about it and says it is something that an electron or proton carry. Is this charge something made of matter having a substance or just a description of an effect? i'm a little bit confused.
    thanks a lot
  2. sparkchaser
    Nov 15, 2007
    5
  3. sparkchaser
    Nov 15, 2007
    5
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Electric charge is a fundamental property of subatomic particles, notably protons (positive charge) and electrons (negative charge). The electromagnetic field is the effect of electric charge which influences the behaviour of electrically charged objects (down to other subatomic particles) within its vicinity.
    Dave
  5. ronn
    Nov 1, 2007
    16
    thanks for your reply
    by analogy , do you mean charge is like what a mass has something to do with gravity?
    thanks again
  6. cheddy
    Oct 19, 2007
    87
    Not so much. Gravity is a universal attractive force. Charge can be either attractive or repulsive depending on polarity.
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Charge is related to which way the particle is spinning as it moves along. If an electron sized particle spins one way as it zinga along, it has a negative charge and we call it an electron. If it spins the "wrong way" while traveling, it has a positive charge and we call it a "positron."
    The two different spins make two different electrical fields that attract each other. Similar spins make similar electrical fields that push against each other. They work sort of like little bitty weather systems. Sort of.
  8. cheddy
    Oct 19, 2007
    87
    Huh? What about ions? Aren't they a little more ubiquitous and easier to use to explain attractive and repulsive forces than matter-antimatter?
  9. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    No. Ions simply have extra electrons or fewer electrons. Charge itself comes from spin.
    Don't blame me for how the universe works, I didn't invent the thing!:D
  10. ronn
    Nov 1, 2007
    16
    from my basic question that i ask
    and deducing from the information that we talked about,
    it looks like charge is not substantial (not material) it is more of
    description of an effect? Am i right?
    thanks a lot for those who answered and give their thoughts of it.
