ELCB/RCD trip time tester project
Jonathan Yeong
Joined May 5, 2015
Hello All,
Im looking for advise on how to create an ELCB trip time tester.
I need to measure how long does the voltage discharging from 240V to 0V.
Does any one have any idea how does the tester works?
MaxHeadRoom
Joined Jul 18, 2013
28,686
You would need to setup a timer monitor of some kind and set a deliberate earth fault and measure it, I don't know of anything that would do it off the shelf.
Max.
Jonathan Yeong
Joined May 5, 2015
Im thinking of using Microcontroller to measure the voltage when i press a "test" button. But im worry that the voltage discharging time may delay cause microcontroller may take sometime to react. Therefore i was thinking any electronic component can make the tester easier...
