I was looking at the data sheet for el wire. Also I would like to know if it is true that although the optimal voltage for the el wire is 120V, I can apply 20-200 AC voltage to it to work?
That's what it says in the datasheet, yes.I was looking at the data sheet for el wire. Also I would like to know if it is true that although the optimal voltage for the el wire is 120V, I can apply 20-200 AC voltage to it to work?
by Duane Benson
by Duane Benson
by Jake Hertz
by Aaron Carman
