EL 2009 Vss voltage query
Discussion in 'The Projects Forum' started by cabinetguy, Dec 25, 2014.
  1. cabinetguy
    Dec 14, 2014
    I'm cosidering using a EL 2009 buffer amp in a function generator output stage (project). The project uses 5v + and - for everything else but I'm not sure if the EL2009 runs on 5 volts. The data sheet shows a max voltage of 18v or so.
    Has anyone had experience with the using the EL2009 on 5 volts?
    I'm thinking it will run on 5 volts, I just don't know for sure.
    Thanks.
  2. WBahn
    Mar 31, 2012
    18,080
    4,917
    Since you want people to look at the data sheet for you, don't you think it would be polite to include a link to the data sheet you want them to look at?
  3. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    The spec sheet shows an absolute rating of + -18v
    And the example shows +-12v
    It appears it may run on +-5, test it and see!
    Max.
  4. cabinetguy
    Dec 14, 2014
  5. WBahn
    Mar 31, 2012
    18,080
    4,917
  6. cabinetguy
    Dec 14, 2014
    Thank you, I'll test it before using it (when it arrives).
  7. cabinetguy
    Dec 14, 2014
    Thank you,
    I'm not very knowledgeble on this, I just love to make things.
    It appears it will run on 5 volts, thanks again.
