EIKO GTL-2 UV-C Germicidal Bulb
Discussion in 'General Electronics Chat' started by magic_eyes, Apr 13, 2012.
  1. magic_eyes
    Apr 13, 2012
    8
    Hey,
    I am an engineering student trying to power a 10V 2W (and thus a .22 A) UV germicidal bulb. Our project is to make a solar powered water purifying bottle that utilizes this bulb. The solar panel will charge two 9v batteries in series outputting to a ~80 ohm resistor connected to the bulb and then back to the solar panel all in series. Upon trying to complete this circuit many times with no success of lighting the bulb at all I called the company, EIKO. They are confident the bulb is functioning and believe the error to be in my circuitry. The tech help stated that the bulb works over a discharge path. He said this may result in the bulb (or something in the circuit) providing infinite resistance. I have received schematics of the bulb itself to confirm this. Any ideas as to what I am doing wrong? Any help would be greatly appreciated. Thank you,
    Ryan
  2. magic_eyes
    Apr 13, 2012
    8
    I just got the bulb to work. The key was just strength of connections and wiring the 75 ohm resistor in parallel with a capacitor.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Congratulations on getting the bulb to work.
    The resistor is a huge power waster. Efficiency is very important in battery powered equipment. Unless your circuit is just for proof of concept, you should consider a switching regulator.
  4. magic_eyes
    Apr 13, 2012
    8
    Interesting. I'll need to do some research myself but where in the circuit would this go? Still in parallel with the capacitor? Or simply replacing that parallel system? My friend also recommended a super-capacitor which I need to look into. Thanks for the advice!
  5. Ron H
    Apr 14, 2005
    7,050
    657
    The switching regulator would replace the parallel RC, supplying a regulated 10V. You might have to design it to put out a higher voltage impulse when first switched on, similar to what your RC circuit does.
    Good switching regulators are more than 90% efficient.
    BTW, how did you come up with 75 ohms?
    (18V-10V)/200mA=40 ohms.:confused:
  6. magic_eyes
    Apr 13, 2012
    8
    Thanks for the info that sounds much better than what we have now.
    The 75 ohms was from standard formulas(without the discharge path) with everything in series. 18v/(~75ohm) = 0.2 amps. Some trial and error was also involved. However the equation you just posted is probably the one we should use as I was having trouble duplicate my success getting 17 volts through the circuit.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    It's a 10V, 200mA (or is it 220 mA) bulb. Ohm's law should let you determine the series resistor value. However, I suspect that UV bulbs have a nonlinear V-I curve, so I don't really know what happens if you use a series resistor instead of a 10V low impedance source.
  8. magic_eyes
    Apr 13, 2012
    8
    We have some switching regulators in the shop on campus so I'll test them out. I think they should be perfect. Thanks again.
  9. vinnie50
    May 4, 2012
    Hello magic_eyes and Ron H
    I have just purchased the same GTL-2 UV bulb for one of my work applications and am also having trouble getting it to light up. I am using a 9V DC source with no series resistance. You had mentioned that you used a capacitor. What value die you use? Also, what voltage did you use? The spec says 10V +-2V, however, I received some info from EIKO that it should be 24V?? Any help would be appreciated
  10. magic_eyes
    Apr 13, 2012
    8
    I believe I used a 36 ohm resistor in parallel with a capacitor or arbitrary capacitance. However, I found a better solution to be using a voltage regulator with a resistance ratio of 7. We did this via a 70kohm wired from pin 1 to the common and then a 10kohm from the common to pin 3. This creates the discharge path necessary for the bulb to light up and provides enough resistance to protect the bulb.
  11. vinnie50
    May 4, 2012
    What voltage did you use? 10V, 24V? I want to try using the right voltage regulator as you mentioned, as well as the resistor/capacitor combination. I will set the circuit up tomorrow and let you know.
    Thanks.
  12. magic_eyes
    Apr 13, 2012
    8
    The bulb takes 10 plus or minus 2 volts. I had it wired off of two 7.2 volt NiMH batteries. The voltage regulator should take care of the voltage as well as the current. You can use a multimeter to ensure you have the right voltage(10volts) getting to the bulb.
  13. Ken Su
    Jul 8, 2012
    Thank you for share your experience.
    I want to purchase a GTL2 UV bulb. But I have a question. Should I purchase any starter or ballast? Thanks for your attention.
  14. magic_eyes
    Apr 13, 2012
    8
    We used a ceramic intermediate screw base to screw the bulb into. This allowed us to more easily attach wires to the base of the bulb. However this was for a custom project.
    Ken Su likes this.
  15. minh
    Member
    Nov 24, 2010
    24
    Dear All..need this circuit for driver GTL-2...
    This circuit in my Eprom UV eraser ,hope is help ,if it work please let me know .Thank you View attachment 44806 .
