EIGHTH GRADE PROJECT CALLED MY CRAZY CIRCUIT MACHINE
Discussion in 'The Projects Forum' started by shannon777123, Jan 23, 2009.
IS THIS PROJECT AS HARD AS IT SOUNDS FOR SOMEONE WITH NO ELECTRONICS EXPERIENCE?
Poll closed Jan 28, 2009.
  1. YES
    0 vote(s)
    0.0%
  2. NO
    0 vote(s)
    0.0%
  3. YOU NEED HELP
    0 vote(s)
    0.0%
  4. EASY AS PIE
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. shannon777123
    Jan 23, 2009
    :confused: PLEASE HELP!!! MY DAUGHTER HAS TO DO THIS PROJECT AND I DON'T EVEN KNOW WHERE TO START:confused:
    I WILL WRITE OUT THE DIRECTIONS AND IF ANYBODY HAS AN IDEA, PLEASE HELP ME.. IT IS DUE JANUARY 28TH, 09.
    DIRECTIONS: YOU ARE TO DRAW THE CIRCUIT NECESSARY FOR A MACHINE THAT YOU WISH YOU COULD HAVE TO WAKE YOU (OR YOUR BROTHER/SISTER) UP IN THE MORNING. IT CAN HAVE ANY WILD AND IMAGINATIVE ATTACHMENTS ON IT YOU FEEL IS NECESSARY TO GET YOU OR WHOEVER UP IN THE MORNING.
    YOUR DRAWING MUST HAVE THE FOLLOWING:
    1. YOUR CIRCUIT MUST HAVE ALL OF THE COMPONENTS REQUIRED TO MAKE IT A CIRCUIT.
    2. YOU MUST HAVE EACH PART OF THE CIRCUIT CLEARLY LABELED.
    3. THE CIRCUIT MUST "WORK". (IT MUST WORK IF YOU BUILD IT - NO NEGATIVES TO NEGATIVES, ETC.)
    4. YOU MUST SHOW THE AMOUNT OF POWER PROVIDED AND THE AMOUNT OF POWER NEEDED BY EACH COMPONENT. OF COURSE, MAKE SURE YOU HAVE ENOUGH POWER TO MAKE YOUR MACHINE WORK.
    5. YOU MUST WRITE A PARAGRAPH OF AT LEAST 5 SENTENCES EXPLAINING HOW YOUR MACHINE WORKS AND WHY YOU CHOSE THE PARTICULAR COMPONENTS IN YOUR MACHINE TO WAKE YOU OR (YOUR BROTHER/SISTER) UP.
    6. YOU CAN COLOR YOUR DIAGRAM FOR EXCITEMENT, USE PICTURES FOR CERTAIN PARTS OF YOUR MACHINE, BUT MAKE SURE YOU KEEP IN MIND THAT IT MUST BE A "WORKING" CIRCUIT.
    GRADING STRATEGY:
    CIRCUIT LABELS - PLAN IS NEAT WITH CLEAR LABELING FOR ALL COMPONENTS.
    CIRCUIT CONSTRUCTION - APPROPRIATE MATERIALS WERE SELECTED AND CREATIVELY MODIFIED IN WAYS THAT MADE THEM EVEN BETTER.
    CIRCUIT PARAGRAPH - PARAGRAPH PROVIDES A COMPLETE RECORD OF PLANNING, CONSTRUCTION, AND SOME REFLECTION ABOUT THE STRATEGIES USED AND THE RESULTS.
    APPEARANCE - ALL ITEMS ARE NEAT IN APPEARANCE. THERE ARE NO STRAY MARKS. COLOR IS USED TO INHANCE OVERALL PROJECT. ALL LABELING IS LEGIBLE.
    THIS PROJECT IS 16 POSSIBLE POINTS WITH 4 POINTS FOR EACH CATEGORY ABOVE.
    PLEASE HELP!!! THANK YOU THANK YOU....
