Hi all.
My team is harvesting energy from sound/vibration using a piezoelectric material. Then, we want to store the energy in some electronic circuit so that it can be used later on to power some load. I found an energy harvesting module called EH300/301 Energy Harvesting Module that is produced by Advanced Linear Devices, Inc.Check this:
http://www.aldinc.com/pdf/EH300Brochure.pdf
The features:
Complete energy harvesting functions
Random AC or DC inputs accepted
Broad range of irregular input voltage, current and
waveforms
Compatible energy harvesting sources:
- PZT, piezo electric fiber composite
- solar photo voltaic cells
- thermoelectric generators
Compatible with most wireless sensor networks (WSN)
Self-contained onboard energy storage
Self-powered and always active
High energy efficiency
High energy retention rate
Long operating life
No calibration or setup required
Maintenance free operation
Simple to use and operate
Optional external energy storage
Optional logic input/output control
Virtually unlimited operating cycles
CMOS logic compatible
Flexible output current range (0.1mA to 1A)
Size AA battery footprint
Moisture and dust protection
I have a question if this module can really be used together with my piezoelectric material to accumulate and store the electrical output?
Also, the module has several series to be chosen?Can anyone tell me what does this number means? I need to choose one of these to work with the piezoelectric to store enough charge to recharge a 3V battery?
Part Number Description
EH300 4.6 mJ Module / 1.8V to 3.6V operation
EH300A 30 mJ Module / 1.8V to 3.6V operation
EH301 8.3 mJ Module / 3.1V to 5.2V operation
EH301A 55 mJ Module / 3.1V to 5.2V operation
The features:
waveforms
Long operating life
