eg 1500 generator
Discussion in 'General Electronics Chat' started by adrian343, May 7, 2009.
  1. adrian343
    May 7, 2009
    i have a eg 1500 generator the is a light next to the volt meter should that light be on all the time or when it overloads
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What is the label next to the light? Does it say "Voltage On", or "Overload"?
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Do you have the EG1500 manual? The only light on the control panel is the pilot light. It should be on when the engine is running.
    I found this manual by going to the Honda web site and following the links.
  4. adrian343
    May 7, 2009
    the light doesent come on when the engines running i took the light bulb out and tested it and it worked
    thanks
  5. Ron H
    Apr 14, 2005
    7,050
    657
    I don't see the reason for the light. Why do you need one to know that the generator is running?
    Can you drive a load (e.g., space heater) with the generator?
    If you really want that light to work, trace out the circuit with a multimeter and find out where the fault is.
    Regarding your PM question, there is no resistor in the wiring diagram.
