Efficient Method of Switching 50v at 25A?
Discussion in 'General Electronics Chat' started by joe426, Dec 6, 2011.
  1. joe426
    Thread Starter Active Member
    Aug 11, 2009
    39
    I have a key switch which can handle 50v at 1A. I need to use it to switch 50v at 25 A. I understand that I can use a MOSFET to switch the higher amperage, but I understand they also burn voltage (voltage drop from source to drain).
    Is there a more efficient method of switching the higher amperage? To my knowledge, there aren't any key switches which can switch this much power. I wasn't able to find a relay which can handle this much current either.
    Thanks!
  2. Jotto
    Member
    Apr 1, 2011
    159
    17
    Use a contactor or selenoid?
  3. jimkeith
    Oct 26, 2011
    539
    99
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    From the details provided a contactor or solid state relay (SSR) will fit your needs.
  5. Jotto
    Member
    Apr 1, 2011
    159
    17
    I would just go to a junk yard and get a 12vdc selenoid off a ford starter.
  6. mcgyvr
    Oct 15, 2009
    4,791
    976
    Not if you were required to meet any standards or didn't want to hold any liability. Most automotive stuff like that is only rated to 32V max or less. That is not sufficient for 50V applications. Will it work.. Most likely.. Is it correct.. No
  7. gerty
    Aug 30, 2007
    1,154
    304
    Also, a solenoid from a starter isn't rated for continous duty, and the OP hasn't given us that information yet.
  8. Lundwall_Paul
    Oct 18, 2011
    222
    19
    If you are hot swapping a load I would stay away from relays or any other mechanical device as this will ruin the contacts. Select some high power FETS and place them in parallel if needed to get the required current.
  9. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    depends on your application. A 'key' switch in industry means a 'safe' circuit, relay required, as solidstate switches are not considered 'safe'. Relays can and do switch heavy loads.
