If I install a 120V stepdown transformer on phases A and B of a 480V 3 phase system & put a large load on the transformer, what will happen to the rest of the components on the 480V system?
What will happen to the power source?
I have read someone mentioning that you need to load the C phase to balance the load, but how do you do that? If you have a higher load between A & B, so you put a load between C & B to balance it out, didn't you just equalize A & C and double the load on B?
