Effects bypass footswitch with LED
Discussion in 'The Projects Forum' started by BassmanL42, Jan 5, 2009.
  1. BassmanL42
    Jan 5, 2009
    I have two audio effects units that have foot switch
    operated bypass functions, which use momentary
    switches. I want to add an led indicator to show when the effect
    is on or off. Can anyone suggest possible solution how to
    configure this. (would be all so :confused:easy if switches were latching!)
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Do you have the schematics of those effect boxes?
    If so we can have a look how to implement the leds.
    Greetings,
    Bertus
  3. italo
    Nov 20, 2005
    205
    I don't see any problems if you can find out what voltage and current is flowing trough those switches. Adding a led it would be mostly mechanical. what you need to lite a LED is 1.8v for red and 10-20ma.
    found out first what you have then I will help.
