Effective voltage rating
Discussion in 'General Electronics Chat' started by RG23, Apr 15, 2011.
  1. RG23
    Thread Starter Active Member
    Dec 6, 2010
    301
    I have 10 pF capacitor with voltage rating of 6kV
    If I connect 7 such 10 pF capacitors in series, what would be the effective voltage rating of that series combination of capacitors?
    If anyone has an idea, please let me know
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    Capacitors connected in series cannot be relied upon to share voltages well. Unless steps can be taken to equalise the leakage currents, it is likely that some of the capacitors will be more stressed than others. This makes the overall breakdown voltage unpredictable.
    With such tiny capacitances, I am doubtful that you could get much performance out of the system by the time you had added leak resistors low enough to equalise the voltages.
  3. RG23
    Dec 6, 2010
    301
    I would like to know the effective voltage under ideal conditions
    Is there any specific formula?
