Effect on inductance in persence of permanent magnet
Discussion in 'General Electronics Chat' started by hubble, Dec 10, 2015.
  1. hubble
    Jun 17, 2009
    22
    Hi, let's say we have an iron cored stator coil having several turns and some current is allowed to flow through it. So, north and south poles are formed. How will the inductance of the coil vary when north or south pole of a permanent magnet is brought near the south and north pole of the stator coil?
    Thanks.
  2. wayneh
    Sep 9, 2010
    12,403
    3,251
    It's complicated. The magnetic field lines of the stator core extend from the poles, out into the room, and eventually loop back to the opposite pole. The magnetic permeability of that path affects the inductance. When you place another magnet into that field, the field lines are disrupted and the permeability changes a little. This in turn would alter the inductance.
    Your cases A and B imply you have monopoles, but I assume you mean a bar magnet in line with the field lines in A and opposite the field lines in B. So in A the permeability of space seen by the stator core is slightly increased whereas it is decreased in B.
    I leave it to you to relate the impact of permeability on inductance.
  3. hubble
    Jun 17, 2009
    22
    Thanks @wayneh for your quick response. Why does coil inductance increase in the first case and decrease in the second case? Here is the variation curve with respect to the above two arrangements: inductance.PNG
    As it is shown in the plot, inductance is decreasing in both the cases, although by different amount. Why is it so?
  4. crutschow
    Mar 14, 2008
    13,518
    3,386
    How are you measuring the inductance?
  5. wayneh
    Sep 9, 2010
    12,403
    3,251
    Just for background there is a reference on this site.
    A picture of your apparatus might be useful. For now I can only speculate that the overall permeability goes up in case B, despite the opposing field of the external magnet. But it could all be artifact for all we know.
  6. hubble
    Jun 17, 2009
    22
    Thanks all for your replies. This is not my setup. I have been trying to understand the working of sensorless brushless dc motor. For now, I am reading up on position estimation and starting methods of these sensorless dc motors. Here is the resource link:
    I just want to understand how this method of position estimation works.
    For that, I need to know how this coil inductance varies by bringing the permanent magnet in coil's close proximity.
    Hope it helps.
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    look up "magnetic amplifier" to see how a magnetic field affects inductors. your circuit shows no inductance, dc through coil will produce how much inductance? inductance is an ac effect, not dc.
  8. BR-549
    Sep 22, 2013
    2,184
    421
    Nature loves perpendiculars. Reorientate your magnet to 90 degrees of coil.
    Try DC first. Then AC.
    Along with distance....try rotation of magnet too.
  9. GopherT
    Nov 23, 2012
    6,330
    4,080
    Look up Lenz's law
