i need to know what exactly happens with the ripple voltage when there is an increase in temperature.
if so why?
please let me know it will be a great help for me.
If the heat changes the actual value of the capacitors the ripple will change. More capacitance will have less ripple. Less capacitance will have more ripple.
Ripple is not a function of any DC-DC regulator. You are introducing this ripple into the circuit elsewhere. (Or not filtering it before) Lack of caps may be causing oscillation, but that can only be hypothesized without seeing a circuit.
