effect of ground
Discussion in 'Physics' started by isha, Oct 2, 2005.
  1. isha
    Thread Starter Active Member
    Sep 16, 2005
    36
    In bridge rectification why we ground the load resistance?
    what effect if we not grounded the load?
    what is advantage in grouding the load?
  2. haditya
    Jan 19, 2004
    220
    the ground usually means a reference terminal for voltage
  3. n9xv
    Jan 18, 2005
    329
    If its not grounded no current can flow through it.
  4. isha
    Sep 16, 2005
    36
    THANKS
  5. isha
    Sep 16, 2005
    36
    current always flow if supply is connected it idoes not depend on ground
    that ground has no physical existence
    its just a reference point
    with respect to this point we see the direction of current flowing through the resistor
