Effecient way to Bleed down a capacitor
Discussion in 'The Projects Forum' started by Geoffr67, Feb 13, 2012.
  1. Geoffr67
    Dec 5, 2011
    69
    Hello everyone,
    I have a circuit i made and am having a problem, It keeps hanging up when i shut power off and then reapply power, while this wont ever really happen in real world,its causing the pic chip to lock out a input when power is reapplied within a few seconds. When the capacitor is discharged after power is removed it works fine. Can anyone suggest a good way to bleed down the cap, are there better options besides useing a resistor between the cap? something that will bleed it down almost instantly?
    Thanks everyone!
  2. K7GUH
    Member
    Jan 28, 2011
    191
    23
    A dead short will certainly do the trick. However, it may not be terribly convenient. Use a relatively high value of resistor across the capacitor, so as not to load down the input of your circuit. You need to know the equivalent resistance of your working circuit, then pick a resistor value 20-30 times that for the bleeder.
  3. Geoffr67
    Dec 5, 2011
    69
    " You need to know the equivalent resistance of your working circuit, then pick a resistor value 20-30 times that for the bleeder."
    So how would i determine this, measure the resistance at the input? and then go 20-30 times that number? Forgive my ignorance on this first time ive ever had to do this.
  4. crutschow
    Mar 14, 2008
    13,501
    3,375
    The equivalent resistance is simply the supply output voltage divided by the supply output current into your load.
  5. luvv
    Member
    May 26, 2011
    186
    31
    Could you use a pnp fet and smaller resistor to dead short the cap when the power is turned off?
    I don't know if it would work,just sounds reasonable to me :)
  6. ErnieM
    Apr 24, 2011
    7,438
    1,626
    When I need something for a breadboard I do something really simple and foolproof. Here that would be a relay on the power input and a diode separating the power in from the cap. When power goes off, the relay opens and the NO contacts can do anything you wish from dead short on the cap to a small resistor or something else.
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    Worked this up as a concept. A couple of open collector inverters would probably work also.
  8. MrChips
    Oct 2, 2009
    12,636
    3,454
    Where is the cap connected? It might help if you provided a circuit. Why not remove the cap? Another solution is to install a POR (Power-On Reset) circuit.
    http://www.maxim-ic.com/app-notes/index.mvp/id/3227
    Edit: Did you enable the Power-On Reset delay on the PIC?
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The PIC should have BOR and WDT options, either or both can probably save you from the latchup situation, although it does also depend on oscillator type.
