eeprom read rookie needs help
Discussion in 'General Electronics Chat' started by LATINSNOOP, Dec 12, 2015.
  1. LATINSNOOP
    Dec 12, 2015
    i bougth the cheapest reader and clips to read a 24c16wp on the board. i got the drivers install n the program seems to be working fine. i read that sometimes it can be done without taking the chip out so i try but nothing. im a complete rookie at this but im a fast learner. i just want to read the chip thats all.. i read that i maybe need an occilator something about keeping the prossesor sleep. maybe i got to get the chip out the board. maybe is the super cheap reader i bought. hope someone can help it will be much appriciated thanks.
  2. joeyd999
    Jun 6, 2011
    2,757
    2,936
    That's probably one problem.
    With that said, the I/O pins are likely loaded via other components on the board which will prevent the reader from working.
    And, just for the historical record, this is my 2,000th post. Thank you. Thank you very much!
    absf and JohnInTX like this.
  3. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Or I could just delete it. :D
    Seriously, a great milestone and not all of them were on the 'Aptitude Test' thread, either!
    Warm Regards, buddy.
    BR-549 and joeyd999 like this.
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    651
    The ability to read/write in-circuit needs to be designed in. Otherwise, if you attempt to power the device from the programmer, it will end up powering the rest of the logic and you may cause damage.
    Post more information on the board the EEPROM is in, including a schematic.
  5. LATINSNOOP
    Dec 12, 2015
  6. LATINSNOOP
    Dec 12, 2015
    everything is appriciated , u think by taking the eeprom out the board then it would b easier 4 me
  7. joeyd999
    Jun 6, 2011
    2,757
    2,936
    I don't think anything. I haven't seen the application so I've no means to form an opinion.
  8. dl324
    Mar 30, 2015
    3,379
    651
    Yes. As an aside, many members, myself included, don't like text speak.
