That is not going to do it either. You don't mention which eeprom or show the eeprom device. My guess is it is in circuit and is SMD so it will be impossible to do unless you can talk to the bluetooth device itself.HaHa, Forgot to ask the question.... How can I Do that ??
I just thought that your IC may included in the programmer that what I linked.How can I ensure that this programmer is 100% compatible to my EEPROM ?
No one can help you unless YOU give more information, like what the IC model is, for starters....Bump, Please help..
You need to find the datasheet for the eeprom, and see if that matches the list in the link given by Scott.What do you mean ??
What are the numbers/letters present on the EEPROM?What do you mean ??
It could be stored in the controller's firmware, in which case, there'd be no way of changing it unless its source code is given to you by the manufacturer(don't count on it...)BTW, Its possible that information like I Mentioned (PIN Code), not on the EEPROM ?
by Jake Hertz
by Jake Hertz
by Duane Benson
by Aaron Carman
