Hey Everyone, happy Tuesday.
So I'm starting on a project to make a signal generator for testing an EEG monitoring system, and I'm not sure where to begin. This is the first major analog project I've ever done, and I'm a bit confused as to where to begin and was hoping for some suggestions, particularly from people that might have some experience with doing this sort of stuff.
The first step is identifying my problem and end goal. I want to be able to generate signals for EEG, so they low in amplitude. Really low. I'm talking in the neighborhood of 10 uV (around 100 uV during seizure)! The frequencies are also pretty low, around 4 to 20 Hz normally (up to 40 Hz during a seizure). I want to first design for a fixed frequency of 10 Hz to keep it simple. As you can imagine, noise robustness is priority since the tiny signals will be swallowed up otherwise. On the plus side, there are no power or size restrictions, since it I am designing a test instrument, and not something that goes in or on a person.
Onwards . . . so the first step is a block diagram, but I guess that requires that I understand some basic blocks first. Some have suggested that I look into oscillators and 555 timers. Any opinions as to what my first research target should be? Thanks in advance for any guidance.
