Editing 555 timer for 60% interval change
Discussion in 'The Projects Forum' started by J7NF, Apr 4, 2016.
  1. J7NF
    Mar 12, 2016
    18
    I need to edit my 555 timer in astable mode to get at least an interval change of 60% for the duty cycle, for example varying from 40 to 100% and so on. I am using a 10k potentiometer and 1 K resistor as R1 and R2 so I cannot go below 52 %. Any idea
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    Lets have a circuit diagram first , then we can see what you need. You can do it with an hysterical circuit using diodes.
  3. dannyf
    Sep 13, 2015
    2,196
    417
    Have you tried to half R7 so that it's time constants with C3//Cr is less than R1?
  4. Alec_t
    Sep 17, 2013
    5,973
    1,135
    :p:):confused:
    Dodgydave likes this.
  5. crutschow
    Mar 14, 2008
    13,501
    3,375
    Below is a 555 astable design whose duty-cycle variation is close to 0-100% with pot position.
    (Shown for pot positions of 1% and 99%.)
    Edit: Either the OUT pin or DIS pin (with pullup) can be used as the output.
    The frequency is approximately 1/(0.73*Rpot*C2)
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
  7. engrBecks
    Mar 31, 2016
