Edge-triggered JK flip flop
Discussion in 'Homework Help' started by dudeperfect, Apr 15, 2015.
  1. dudeperfect
    Apr 15, 2015
    I have this scheme:
    And here is my test code:
    Code (Text):
    1. clock_proc : process begin -- sinchrosignal ą valdantis procesas
    2. x1 <= '0';
    3. wait for 8 ns ;
    4. x1 <= '1';
    5. wait for 8 ns ;
    6. end process ;
    7.
    8. reset_proc : process begin -- nustatymo i 0 signal ą valdantis procesas
    9. reset <= '0';
    10. wait for 2 ns ;
    11. reset <= '1';
    12. wait ;
    13. end process ;
    14.
    15. test_proc : process begin -- trigerio signalus valdantis procesas
    16. x2 <= '0'; x3 <= '0'; x4 <= '1'; -- saugo
    17. wait for 5 ns ;
    18. x2 <= '1'; x3 <= '1'; x4 <= '0'; -- iraso 0
    19. wait for 5 ns ;
    20. x2 <= '0'; x3 <= '0'; x4 <= '1'; -- saugo
    21. wait for 5 ns ;
    22. x2 <= '1'; x3 <= '1'; x4 <= '1'; -- iraso 1
    23. wait for 5 ns ;
    24. x2 <= '0'; x3 <= '0'; x4 <= '1'; -- saugo
    25. wait for 5 ns ;
    26. end process;
    It should reset Q to 0 at the beginning, then hold, then reset it to 0, then hold, then set it to 1 and then hold. But what I get is this:
    As you can see, at the beginning when Q should be reset to 0, it is set to 1 and then stays at 1 till the end. J and K are okay, so I guess something is wrong with my scheme, but I can't find the issue.
    It would be great if someone could check out it and maybe spot the mistake.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Have you implemented this layout using a set of Boolean equations? If so, I'd recommend going through each data path and find out if your implementation matches your equations.
    What are x1-x4 supposed to be/do?
  3. dudeperfect
    Apr 15, 2015
    I used the same boolean equations while doing the static JK trigger, and it works fine. Even master-slave implementation is done great, so I guess equations are OK.
    I add them here, not a lot of computations.
    And x1-x4 are the inputs. I assign values to them in my test code.
