Edge Detection circuit causes dips in power line
Discussion in 'General Electronics Chat' started by Mellowed, May 15, 2016.
  1. Mellowed
    Mar 6, 2016
    13
    I'm trying to put together an edge detection unit for a delay measurement unit using the CTMU of a PIC micro-controller.
    The edge detection seems to work as shown in the image below, however i see a negative dip after the falling edge. I noticed that the dip is present in the Vcc power line as well. I think this is causing issues with my CTMU since its giving me negative readings for very short periods :(
    Is it possible to remove this dip?
    My setup is very simple for the result below. An arduino uno produced a pulse every 1us which is connected to an edge detection setup as shown below upload_2016-5-15_21-15-37.png
    I also noticed that the strange wave produced after the falling edge is visible on my PIC uP whenever a pulse is produced on a pin :(
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. crutschow
    Mar 14, 2008
    13,508
    3,385
    Is the probe ground connected close to the point you are measuring?
