ecu swap (bosh) of benz
Discussion in 'Automotive Electronics' started by arunpradh, May 25, 2016.
  1. arunpradh
    Dec 11, 2013
    43
    can any one help me to get the software and transponder key programming of benz? my old ecu was dead due to water damage.i got an ecu from another car of same model and i think its good.i need to match it with my car.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I'm going to guess that it is not exactly open source. I'd be surprised if there was a copy in the wild.
  3. KeepItSimpleStupid
    Mar 4, 2014
    1,297
    225
    I have a Toyota and the transponder key programming is DEPENDENT on having a working MASTER key if your programming on a car.
    The programming sequence is nuts. Your actually letting another key operate the vehicle. When I did it, it was a 20 minute process after the key was cut.
    In some cases, the programming systems require locksmith credentials to obtain.
    Refurbished ECU's come in a given state, but I don't know how transponder or security such as the radio being matched to the VIN issues are handled.
    To even get any response at all, the model and year needs to be given.
    Chevrolet is now requiring that the software be "rented" with a minimum 3 day rental. Key stuff is still off limits without "credentials".
  4. bwilliams60
    Nov 18, 2012
    734
    94
    You will need to take it to a dealer and have them flash the ECU to the car. Not cheap but cheaper than any other way you are going to find. All O EM software is proprietary in automotive.
  5. cork_ie
    Member
    Oct 8, 2011
    348
    58
    A lot depends on the age and ECU type. Mercedes & Bosch covers a range of about a thousand different ECU part numbers.
    Many older Bosch ECUs had the immobiliser data located on an eeprom chip in the ECU.
    If you can locate the eeprom on the ECUs and swap them over, it should solve your problem.
    arunpradh likes this.
  6. bwilliams60
    Nov 18, 2012
    734
    94
    EEPROM is the newest style which is flashed with software. Removable chips are PROM chips. Some immobilizer data is contained on the instrument cluster. We need more info to help you.
