Wookie, without the zener won't the input transistors on the op-amp cook when there is a spike on the line?Remove Z2.
Replace R2 with a 10k Ohm resistor.
The LM358 is a dual opamp. You need to connect the output of the side you're using to the non-inverting (+) side of the unused side, and the output of the unused side to the inverting (-) input of the unused side. Otherwise, it may oscillate and cause problems.
The op-amp is in an unusual package (looks like SIL - single in line) instead of a DIP (dual in line), as I would recommend. The LM358 is so common, it is about 35 cents in low quantity; you should make certain they don't have any.Sorry for my confusion, but what voltage am i supposed to see being fed to the speedometer?
To clarify further, I was given another Op Amp P/N NTE928S by the Store, they said it was the same as the LM358 and I should use the connections as per the wiring diagram that (tom66 made) as follows:
Connections have been made are as follows:
Pin 1: 8 volts from voltage regulator
Pin 2: Output A to speedometer
Pin 3: Jumped to pin 2
Pin 4: Input from VSS signal
Pin 5: Chassis ground
Here is the linj to the NTE spec sheet.
http://www.nteinc.com/specs/900to999/pdf/nte928s.pdf
I have done this now is it correct?
Sorry, the jumpers I specified were for the NTE chip, the LM358 would have:Ok I have started again.
I managed to get an LM358(M) and built a new board as per the wiring diagram.
Op amp is now connected as follows:
P1: To Speedometer input
P2: Jumped to P1
P3: 10K resistor and vss output signal from the sensor
P4: To chassis Gnd
P5: Jumped to P1
P6: Jumped to P7
P7: Jumped to P6
P8: To voltage reg.
Result on driving: VSS code does not trip (which is OK), however still no speedo reading.
In your last post you mentioned to connect 6 and 7 to the vss terminal, was this for the NTE amp or the LM358? Also should I remove the 10k resistor and go back to a 47 ohm ?
This must be as frustrating for you as it is for me. LOL
The interconnect is for the power connections between the two amps; it is only indicating that the power pins are shared for the two op-amps on the chip.Tom66
This is the datasheet link for the LM358M amp i have, the pin config is on page 9. Looking at the schematic there seems to be an internal interconnect between the amps, will running the pins on the unused section to ground cause a problem?
http://www.datasheetcatalog.org/datasheet2/d/0krxqjyrr14uhy7yk1if661zzqwy.pdf
I have checked the voltage reg output, it is giving 8.07V at pin 8 with 12v applied.
Thanks for the support!
Can you show us a picture of your board? I want to make sure everything is connected okay.tom66
I rewired the board as per your suggestion (omitted pin 7 for the moment), tested on car with the same results ECU ok, no speed reading.
FYI.
I tested on the bench using 11.3v input, and measured voltages on the input and output lines on the board, saw 0.527V on input line and 6.09 on the output to the speedo.
Jumped pin 7 to ground pin 4 and saw the same results.
Is this result what is expected?
It is apparent then the op-amp is working correctly, but I can't figure out what is wrong with your circuit. I would double check all your solder joints - some of them are quite dodgy.Performed a Bench test with 10.46 voltage source.
Pin 2 connected to gnd (and nothing else) out[ut to speedometer is 6.71V and input signal wire reads 0.575V
Pin 2 connected to output of voltage reg output to speedo is 0.007V and input signal wire reads 0.728V
by Duane Benson
by Jake Hertz
by Duane Benson
by Jake Hertz
