ECG calibrator using LM555
Discussion in 'The Projects Forum' started by ekastia, Feb 17, 2011.
  1. ekastia
    Feb 17, 2011
    Hi, azzy.. i'm working on ecg kalibrator too. how about ur project is it work well by using LM555??
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Depends, maybe, if you aren't too finicky about waveforms. I suspect it is pretty important, but maybe not.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    If you have PC running windows XP or higher. I can make a app for you using the sound card. But you must be able to download a 25 Mbyte runtime engine (free) A sound card is not so good for lower frequencies. So the ECG wave will not be optimal. But I leave it to you to decide.
    If you are a Labview user I can send you the source code.
