ECE.. Memory!
Discussion in 'Homework Help' started by C.J., Feb 7, 2009.
  1. C.J.
    Feb 7, 2009
    A 16 KB memory has a 16 bit wordsize. How many 16 bit words total can be stored in this memory?
    I tried many things. My answer were 2e12, 2e13, and 2e14. All of these were wrong. Please help soon (if you can. I only have until midnight and have been working on this for over a day. It's not that difficult but I just can't get it.
    A byte is 8bits.
    KB means 1024bytes
    Any suggestions?
    WHOOPS SORRY DIDNT MEAN TO POST.
  2. Cabwood
    Member
    Feb 8, 2009
    20
    First, figure out how many bits of data your memory stores. You used a capital 'K', which I shall assume means 'kilo". If that's the case then you should have used a lower case 'k'. The difference may not seem like much, but it's important. Using the wrong case in your units is a cardinal sin.
    The capital B you used tells me 'bytes'. This is probably not the case, because memory ICs capacities are usually expressed in bits. If this is the case, then you should have used a lower case 'b'. A single byte (1B) corresponds to 8 bits (8b).
    OK, assuming your memory is a sixteen kilobit device, it has a capacity of 16 * 1024 = 16384 bits. If you meant 16 kilobytes then its capacity is 16 * 1024 * 8 = 131072 bits.
    Each word for your device is 16 bits. How many of these chunks of 16 bits would make up a total of 16384 (or 131072, if you meant kilobytes)? You do the math.
