I think that this thread has proved this to be true You need to make your own best guess at what is likely to suit you.Everybody has different opinion and requirements. Yes ?
Oh yes indeed. And I think personality has something to do with it--whether we like the idea of something already set up and structured for us, versus something that we create from scratch every time we use it. Beyond the obvious fact that we're working with processors that are already complete, though if you're using PICs, you have an incredible number to choose from.Everybody has different opinion and requirements. Yes ?
What kind of issues my friend. A PICKIT 3 should work out of the box. But in some cases you may have problems like Eric007 here. And the fix is easyI have added the LCD plus some goodies..total comes to $208.00 I can afford tht.
Plus the pickit3 retched send me is having issues. I was not able to program even one chip with it yet.
You are entitled to buy the discount version if you have already bought a compatible development board from the same supplier.That compiler you at the last lint, t0. Page shows discount, $199.0 .wht's up with that?
Are those the same as the $249 ones ?
Sorry, meant DHL.... must stop relying on memoryI will get the compiler later and I chose DHL.
They say it's $25.00 each time. what ever the courier.
I suspect that you may have overlooked one little fly in the ointment:- I do not think that Hardware Debugging is workable with the set-up that you describe:Like ErnieM said you can use any compiler you like, or even work in ASM if you like.
All that is required is that your compiler can call an external programmer .exe which they all can these days.
So you can work in the compiler you prefer, and just press "build and program" on that compiler and it will automatically send the compiled HEX to the EasyPIC7 which programs the PIC in the socket.
by Duane Benson
by Jake Hertz
by Jake Hertz
