Sorry this must be some easy questions but I am lost in this assignment.
Does insulation of a wire affect its resistance? Explain
List 4 factors used to select wire for a specified current rating?
What are the most common insulator used for extremely high voltages. Explain your answer with, at least, two points for each insulator. Hint: They can withstand much higher temperatures than rubber insulation. The first is in tape form and it would is wound around the conductor in layers. The second is infused with mineral oil.
