easy hw question
Discussion in 'Homework Help' started by walker_hunter, Mar 16, 2008.
  1. walker_hunter
    Mar 15, 2008
    what is the difference betwen shorted circuit and open circuit in a thevenin theorom circuit. In my understanding i think that both (shorted and open circuit ) is that current dos not flow throw it.
  2. S_lannan
    Jun 20, 2007
    247
    I never needed to study thevenin circuits but i can tell you this.
    If a thevenin circuit is connected to an open circuit the output voltage will be Vth and no current will flow out of the thevenin circuit.
    If the thevenin circuit is connected to a short the output voltage will be zero and the current should equal Vth/Rth.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    It is typically part of the process of deducing the Thevenin resistance by removing power sources from the circuit - voltage sources are replaced by a short circuits, current sources are replaced by an open circuit. Intuitively, the short circuit will tie two nodes together, the open circuit will produce an infinite resistance between two nodes.
    Dave
