Easiest way to make an amp?
Discussion in 'The Projects Forum' started by kevin gonzalez, Aug 1, 2015.
  1. kevin gonzalez
    Jul 30, 2015
    Can anyone tell me what is the easiest way to amplify sound. Ex-a transistor amp ? Any info would help
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    Buy an audio amplifer?
    (Ps. The quality of answers on this forum is directly proportional to the quality of your question)
    #12, ScottWang, Sinus23 and 2 others like this.
  3. ebeowulf17
    Aug 12, 2014
    682
    79
    There are ICs that do most of the work for you, possibly similar to the mystery chip in your other thread. The lm386 seems to be a very popular choice, though I have no personal experience with it. Its datasheet includes lots of example circuits, plus there are countless sources online of complete breakout board amp circuits based on the lm386 if you'd rather go that way.
  4. tjohnson
    Dec 23, 2014
    618
    122
    I asked a similar question a few months ago in this thread: http://forum.allaboutcircuits.com/threads/simple-pc-audio-amplifier-circuit.109732/
    It is possible to build a functional speaker without an IC using transistors, but the sound quality will vary directly with the complexity of the circuit. You can build an amplifier circuit with just one or two transistors, which will offer extremely poor sound quality. Alternatively, you can build a more complex circuit with lots of semiconductor components, but it's much simpler to use an IC like the LM386. So unless sound quality isn't important to you or you want to build a complex circuit to learn the details of how amplifier circuits work, I'd suggest the same thing @ebeowulf17 did.
  5. Veracohr
    Jan 3, 2011
    559
    77
    Do you just need to amplify voltage or also drive a speaker?
  6. Alec_t
    Sep 17, 2013
    5,950
    1,129
    Use a megaphone?
    Sinus23 and ebeowulf17 like this.
  7. CoolBeer
    Mar 29, 2010
    40
    6
    Easiest way? lm386.
    Next easiest way? Opamp with a push-pull transistor stage in the feedback loop.
    Balls to the wall way? Three stage(LTP, VA, Output) transistor amplifier, read "Designing Audio Power Amplifiers" by Bob Cordell. (Highly recommended read btw).
  8. GopherT
    Nov 23, 2012
    6,297
    4,019
    Easiest way, buy an amplifier. Plug you signal into the " input" and speakers to the "speakers" jacks. Big range of power and quality options available. What is the source of your sound? Microphone, guitar pickup, phonograph, MP3 player, ...
    Each will have special requirements for amplifier - make sure to pick one that is intended for your source.
  9. ScottWang
    Aug 23, 2012
    4,924
    776
    Easiest way, buy an amplifier online, pay online, choosing the home delivery, stay at home and drink tea to waiting for the amplifier coming ... :D
    ebeowulf17 and GopherT like this.
  10. ScottWang
    Aug 23, 2012
    4,924
    776
    Needs power or without power?
  11. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    For a quickie - I just use an amplified PC speaker.
    Usually my signal source wants a high impedance, so I just add a JFET source follower - the volume pot is usually about 4k7, so that can be used as the source load resistor, needing to add only 2 components; the JFET and its gate leak resistor............Oh!... and a DC blocking capacitor.
  12. #12
    Nov 30, 2010
    16,655
    7,293
    Could you give us a little less information?
  13. ian field
    Oct 27, 2012
    4,447
    791
    You stick a few bits in the back an' it makes it go louder.
    #12 likes this.
  14. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  15. ScottWang
    Aug 23, 2012
    4,924
    776
    One resistor adds totem pole driver using two bjts.
  16. KeepItSimpleStupid
    Mar 4, 2014
    1,250
    218
    How about a string and two paper cups.
  17. takao21203
    Apr 28, 2012
    3,577
    463
    Pam8403 module
    Order from me get it in a week or less
  18. ian field
    Oct 27, 2012
    4,447
    791
    Paper cups tend to be a bit fragile - most people use baked bean tins, and transmit rude noises.
  19. atferrari
    Jan 6, 2004
    2,663
    783
    Why do I feel that this train (or is it thread?) is derailing very fast?
  20. #12
    Nov 30, 2010
    16,655
    7,293
    It's what I call a, "drive by" posting.
    Fire a question. Provide no details. Never respond again.
