Eagle Software Clearance Error
Discussion in 'Electronics Resources' started by tomizzo11, Feb 9, 2015.
  1. tomizzo11
    Aug 21, 2014
    I'm attempting to create a PCB using eagle software. I ran the DRC and am getting a clearance error that is stemming from this faint blue line. I have no idea what this line is, but when you zoom in, it's cross hatched faintly. There is no way to delete it. Any help?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Welcome to AAC.
    b-restrict? Post your files (zip them). That is the only way we can determine what it is from.
    John
  3. sirch2
    Jan 21, 2013
    1,008
    351
    The blue hatched area is there to tell you where the clearance problem is. You cannot delete it but if you sort out the clearance at that point and run the DRC again it will go away. You can either move things, change pad/trace widths or change the DRC clearance limits.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    I agree with Sirch. I had not read the question carefully enough to recognize that the blue hatched line only appeared after running DRC. Still, the problem is not obvious from what is posted, as other traces are even closer together and do not have a clearance error. Attaching your .brd file or both files will help.
    John
