Thanks. Those all should be quite easy to route and space better. I'll do it in the morning, though. Then I'll hopefully have a complete board!I've added a yellow circle in the areas I think is a little bit close...
They look fine to me. I'm not sure what you think is wrong...Guess the regulator is on the bottom side, since its mirrored...
I think the routing is better too. But should some of the caps be moved nearer the IC its supposed to 'protect'. (Or did I get the last posts from Sarge wrong? POST #30)
I don't think its wrong, but have you read this:They look fine to me. I'm not sure what you think is wrong...
Done with that! I wasn't sure whether or not to attach C9 (the new cap by U2) to a trace as close as possible to the pin on U2 or whether to take the shortest route to V+ (up instead of right like it currently is).Yes, that's looking better; but you still have a few items to address (yeah I know, picky picky... )
The anode supply rail for LED1 thru LED19 now runs through all of the pads instead of being above them. That's a pretty easy fix; just takes some clicking and dragging with the SPLIT tool (directly above the ROUTE tool) with the wire bend set to 45°.
C7 (?, can't tell, trace overlaps the NAME) the 100uF cap connected to +V on the left - make it so that just one trace goes to the positive pad; slide the connecting wires to the left.
C3 (near IC1) should be moved over near pin 3 of U1.
U2 also needs a 0.1uF cap like C3. You'll need to add it to the schematic, then move it into place and route it on the board. I'd place it just to the left of U2.
C7 (by the 7805) has three traces running into the right hand pad; make the junction away from the pad, and a single trace to the pad.
C8 needs to have just 1 trace going to the upper pad.
The regulator input terminal (on left) has the trace running through the pad.
On U1, there's a top-side trace between pins 6 and 7; no reason you can't send that trace to the bottom. Same trace, pins on U2.
R7 has a trace running through the right pad. You might rotate R7 and place it below R8 to get some extra room - or just slide it to the left a bit.
Other than that, it's looking pretty good.
Just running a short trace from the cap's pad to the "thru" +V trace will be fine.Done with that! I wasn't sure whether or not to attach C9 (the new cap by U2) to a trace as close as possible to the pin on U2 or whether to take the shortest route to V+ (up instead of right like it currently is).
You're getting close.I tried to make as many more edits to multiple traces per pad as I could to reduce it to one trace.
You can get the individual components aligned to the grid by setting the grid to the desired spacing (normally 0.1" or 100mils, but frequently during parts placement, I'll go to 0.05" or 50mils), and then ctrl+left-click on the component that you wish to "snap" to the grid.Also, many items are off grid (on grid, but to a different grid). Is there an easy way to fix this? There are many components that have very small traces that lead a pad to the correct grid, when this really isn't necessary if I can get everything on the same grid.
It was something like this I was talking about. I think the PCB is coming out real nice.C3 (near IC1) should be moved over near pin 3 of U1.
Oh gotcha. Yeah, I was really just following the schematic I found online. I didn't entirely know effective it was other than that, on paper, everything looked like it should work.It was something like this I was talking about. I think the PCB is coming out real nice.
Cool stuff. I think I'm going to use BatchPCB. Seems like a pretty good service and the price is low. My traces and distances should be enough where it won't overflow too badly.That looks pretty good to me; nothing obviously wrong that jumps out at me.
There's some really minor stuff that I'm not even going to mention. You could spend another week trying to get the board "perfect", but you're at the point of rapidly diminishing returns. Time to get some prototypes made.
by Jake Hertz
by Duane Benson
by Jake Hertz
