Hi there. I'm having some issues with the routing done in Eagle on my pcb. I'm building a VU meter with an LM3915 and LM3916 based on the schematic here. Attached are jpeg's of both the schematic I've made and the resulting PCB, and the original Eagle files. When I'm looking at the PCB, it doesn't have the +12V and -12V separated. There's only +12V. What have I done wrong? The only differences in my schematic and the one I'm copying is that I've used screw terminals instead of just leaving a hole in the pcb to solder a wire to. What do I need to do to make sure that I have both +12V and -12V, as per the original schematic I'm copying? Thanks for all your help!
