Having failed to get CADON for Intellicad running in XP, I decided to take the Eagle challenge. It was steep at first, but I have a simple layout to try. Eagle does not produce the pretty schematics that other packages do, but the pcb layout is "slicker than snot on a doorknob". the NPN package I chose was all wrong, but I was given many choices to change it without visiting a library. The entire program is actually as "kludgy" as a 3D mechanical package (running on a UNIX box) that I mastered in the '90's. THAT package stated that the calculator used "Reverse Polish" data entry. It's late, I'll attempt output tomorrow.
