I have Eagle all set up on my computer and working, but I am having trouble using the netlist to schematic utility. I created a simple test schematic (to see how the utility works) with a resistor, capacitor, and a diode, and simple connections between them. I then exported the netlist and partslist using the schematic export menu item. I then created a new project for the purpose of importing the netlist to see how well the utility works. First, I can't figure out how to use the partslist file to get the individual components into the new schematic. Thus, I manually placed the same parts into the schematic with the correct reference designators as the original schematic, but with no connections. I then ran the cmd-net-list2sch.ulp utility and selected the original netlist file, but it returns an error "Device D1 pin 1 not found". Any ideas?
Thank you very much for your time,
Andrew
Andrew,
You need to attach the netlist that you exported.
Make sure that it has a .txt extension, or it will be rejected by the board software.
Welcome to AAC.
Your post asked about a different netlist problem than the original thread - http://forum.allaboutcircuits.com/showthread.php?t=9425 - so now you have your own confusing thread, as I blew the merge. I completely missed that the original thread was over a year old. Pardon is begged from all.
Andrew
Andrew,
Welcome to AAC.
