E8285A CDMA Test Station Bandwidth
Discussion in 'General Electronics Chat' started by Sparky49, Apr 26, 2016.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi all,
    I was looking at the spectrum analyser option of the E8385A test station, and the documentation seems to suggest that the bw for this is between 800MHz-1GHz and 1700Mhz to 2GHz.
    http://www.libertytest.com/assetmanager/uploaded/pdf-2010512-133233-at_e8285a.pdf page 4
    However, I found a video of someone using it at 145MHz:
    I presume I am reading the specifications incorrectly. If so, what is the actual bandwidth of the instrument, if one were to use it as a spectrum analyser?
    Many thanks for your time,
    Sparky
  2. Sparky49
    Jul 16, 2011
    835
    417
    Ah I see that it is likely an issue of firmware, the newer versions being locked to 800MHz +.
