E&M pinout identification
Discussion in 'Computing and Networks' started by guettafor, Feb 13, 2015.
Thread Status:
Not open for further replies.
  1. guettafor
    Mar 18, 2012
    Hi‚
    I have a VPN getway that I want to use with the E&M for telephony‚ the problem is that I can’t identify the pins of the E&M nor its type. There is no RJ connector, all the E&M Cable Pinouts (8 pins) are connected in a matrix .. So I don't know exactly where is the E lead, M lead, Tx, Rx, .. etc
    Is there anyway to do this‚ maybe using a voltmeter or Ohmmeter?
    Thanks in advance‚
    Kind regards.
    Abder
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    You already have this posted in another forum on the site from less than four hours before this post. If you don't get an answer in another four hours are you going to post it in yet another forum?
  3. MrChips
    Oct 2, 2009
    12,636
    3,455
    One thread is enough.
Thread Status:
