Dynamically Double Resistance?
Discussion in 'General Electronics Chat' started by 3dOptics, Apr 11, 2014.
  1. 3dOptics
    Mar 15, 2009
    13
    I have a potentiometer that has a range of 0-70ohms. I have a resistance gauge that measures 0-140ohms. Is there any way I can dynamically double the potentiometer resistance? Thanks.
  2. kubeek
    Sep 20, 2005
    4,691
    806
    Use two in series?
  3. joeyd999
    Jun 6, 2011
    2,759
    2,943
    Dynamically, you say? Look up "gyrator".
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Is this for a fuel gauge mod?
  5. 3dOptics
    Mar 15, 2009
    13
    Yes. The fuel sending unit on the tractor has a range of 0-70ohms. I thought a reproduction gauge would be the same ohm range but it is 0-140ohms. I could replace the sending unit or find an original gauge that is the correct ohm range, but I was hoping there would be another solution.
  6. inwo
    Nov 7, 2013
    2,435
    315
    Is this gauge connected directly from +12 to grounded rheostat?
    Can you measure current at full and empty range of the gauge you will be using?
    Or find more specs?
  7. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Here's one way you could effectively double the pot resistance.
    The 70 Ohm pot plus components in the dotted rectangle of the right-hand circuit behave similarly to the 140 Ohm pot in the dotted rectangle of the left-hand circuit. The graphs show that the voltages at points p1 and p2 track each other as the pot resistances are varied from min to max.
  8. 3dOptics
    Mar 15, 2009
    13
    Thanks. Where do I hookup the gauge? I built the circuit in CircuitMaker but I can not get it to work correctly.
    What simulation software do you use?
  9. #12
    Nov 30, 2010
    16,705
    7,358
    How about just reducing the voltage to 6 volts?
  10. Alec_t
    Sep 17, 2013
    5,980
    1,138
    R1b represents the gauge, so the gauge connects to the collector of Q1 (point p2).
    LTspice (free download from Linear Technology).
    You don't have R1b going to 12V in your circuit.
