Dynamic port bits
Discussion in 'Embedded Systems and Microcontrollers' started by varunme, Dec 19, 2011.
  1. varunme
    Sep 29, 2011
    59
    How can we access port bits using loops like this in mikroC ?
    Code ( (Unknown Language)):
    1.
    2.
    3. #define _TOTAL_LIGHTS 5
    4.
    5. for(i=0; i<_TOTAL_LIGHTS; i++)
    6.              {
    7.                      if (PORTD.[i] == 1)
    8.                         {
    9.                                  PORTC.[i] = 1;
    10.                         }
    11.                      else
    12.                        {
    13.                                  PORTC.[i] = 0;
    14.                        }
    15.             }
    16. [/i][/i][/i]
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    Use a switch/case statement.
  3. varunme
    Sep 29, 2011
    59
    no way to access by for loop like this ?
  4. MrChips
    Oct 2, 2009
    12,636
    3,454
    No. The part after the dot is a member of a structure. It is not a variable.
  5. AlexR
    Jan 16, 2008
    735
    54
    I don't use MicroC so I don't know if there is some simple MicroC specific way to do it but the following method will work in any version of C.
    1.
    2. #define set_bit(ADDRESS,BIT) (ADDRESS |= (1<<BIT))
    3. #define clear_bit(ADDRESS,BIT) (ADDRESS &= ~(1<<BIT))
    4. #define toggle_bit(ADDRESS,BIT) (ADDRESS ^= (1<<BIT))
    5. #define test_bit(ADDRESS,BIT) (ADDRESS & (1<<BIT))
    6.
    7. #define _TOTAL_LIGHTS 5
    8.
    9. void some_function(void)
    10. {
    11.     for(i = 0; i<_TOTAL_LIGHTS; i++)
    12.     {
    13.         if (test_bit(PORTD, i))
    14.         {
    15.             set_bit(PORTC, i);
    16.         }
    17.         else
    18.         {
    19.             clear_bit(PORTC, i);
    20.         }
    21.     }
    22. }
    23.
    varunme likes this.
  6. ErnieM
    Apr 24, 2011
    7,437
    1,626
    As long as you insist on using a loop you will be using more code and a longer time to execute then just doing a direct assignment:
    1.
    2.         LATC.B0 = PORTD.B0;
    3.         LATC.B1 = PORTD.B1;
    4.         LATC.B2 = PORTD.B2;
    5.         LATC.B3 = PORTD.B3;
    6.         LATC.B4 = PORTD.B4;
    7.
  7. spinnaker
    Oct 29, 2009
    5,078
    1,179
    I have often wanted to pass a port or latch in a function call myself. I have yet to figure out a way to do it.
    pseudo code example
    void foo(PortType port)
    port = 1;
    I realize you can do it with #defines but it would be nice to be able to pass a port or latch as a argument in a function.
  8. ErnieM
    Apr 24, 2011
    7,437
    1,626
    You can always pass the port by reference, ie, by passing the address of the port:
    1.
    2. void ClrPort(near unsigned char* Port);
    3.
    4. void main (void)
    5. {
    6.   ClrPort(&LATA);
    7. }
    8.
    9. void ClrPort(near unsigned char* Port)
    10. {
    11.   *Port = 0;
    12. }
    13.
  9. varunme
    Sep 29, 2011
    59
    I am using 16F , so i cant use the LATCH
  10. ErnieM
    Apr 24, 2011
    7,437
    1,626
    They you use PORT.
  11. varunme
    Sep 29, 2011
    59
    nice , hahhha
  12. thatoneguy
    Feb 19, 2009
    6,357
    718
    Just declare all of your variables globally. :D Buy a PIC with enough RAM first.
