As seen in post #1I want to keep the two hot legs of the 240 line balanced,
I am not sure if that is a response to my question, but the reason for my question is that if he doesn't use the 240, he can simply flip a switch on the generator and put both windings in parallel; thus they are automatically balanced.As seen in post #1
I thought this is what I proposed in post #5, maybe not worded exactly the same.?Tracecom - that's a thought, to eliminate the balancing (and the need for two devices). That creates the problem of then having to make one device twice as large. May be simpler that way. As I am still in the planning phases and haven't hooked up the generator yet, I could consider that. Still need to design one device, but numbers/values would change.
