duty rating of those auto cube 40 amp 12vdc relays?
Discussion in 'General Electronics Chat' started by sdowney717, Mar 20, 2015.
  1. sdowney717
    Jul 18, 2012
    398
    14
    Can they run continuously ?
    What is the DC input range on the high end for that?
    Seeing alternators may get to almost 15vdc, It must be at least that high.
  2. blocco a spirale
    Jun 18, 2008
    1,462
    371
    Yes they can be powered continuously and since they are designed for automotive use; they will be ok with the typical automotive voltage range.
    Roderick Young likes this.
  3. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    The 40amp refers to the contacts, they probably won't last too long with a 40amp Inductive load, Resistive, maybe.
    Max.
  4. mcgyvr
    Oct 15, 2009
    4,793
    976
    While they are fairly standardized.. They are not all created equal..
    The best answer to your question is to "read the datasheet"...(RTFDS)
